メインコンテンツにスキップ
Supersonic Matrix SC-91MID Speakers Replacement
必要な工具と部品
  1. Supersonic Matrix SC-91MID Speakers Replacement, Back cover: 手順 1、 1の画像 1
    • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
    • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
  2. Supersonic Matrix SC-91MID Speakers Replacement: 手順 2、 1の画像 1
    • Use a spudger to carefully disconnect the display ribbons from the motherboard.
  3. Supersonic Matrix SC-91MID Speakers Replacement: 手順 3、 1の画像 1
    • To remove the battery, use the spudger to pry the battery up and away from the tablet.
    • You might have some difficulty removing due to glue holding the battery in place.
    • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
  4. Supersonic Matrix SC-91MID Speakers Replacement: 手順 4、 2の画像 1 Supersonic Matrix SC-91MID Speakers Replacement: 手順 4、 2の画像 2
    • Use a spudger to remove the speakers.
    • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
  5. Supersonic Matrix SC-91MID Speakers Replacement, Speakers: 手順 5、 1の画像 1
    • Desolder the four speaker wires connecting the speaker to the motherboard using a soldering station.
    • If you're unfamiliar with soldering or desoldering check out this guide はんだ付けとはんだ除去の作業ガイド
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    • The tool in the picture is not required for this step. It is just being used to point out the wires.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Andrew Osborn
メンバー登録日: 03/21/17
134 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S46-G4, Bennett Spring 2017 Texas Tech, Team S46-G4, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S46G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 190
