メインコンテンツにスキップ
SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement
必要な工具と部品
  1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Back Cover: 手順 1、 1の画像 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 2、 1の画像 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 3、 2の画像 1 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 手順 4、 3の画像 1 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 手順 4、 3の画像 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: 手順 4、 3の画像 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 5、 3の画像 1 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 5、 3の画像 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 5、 3の画像 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: 手順 6、 2の画像 1 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: 手順 6、 2の画像 2
    • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
  7. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 7、 1の画像 1
    • With the screws removed you should easily be able to remove the camera unit.
  8. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 8、 2の画像 1 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: 手順 8、 2の画像 2
    • Follow the camera unit back to the motherboard.
    • Use the spudger tool to remove the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Harris Dagha
メンバー登録日: 03/26/15
866 ポイント
7のガイドは作成済み
チーム
Dr Shaverz boyz Dr Shaverz boyz人のメンバー
Community
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 230
