メインコンテンツにスキップ
SuperSonic Matrix Mid SC-999 Microphone Replacement
必要な工具と部品
  1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: 手順 1、 1の画像 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Microphone Replacement: 手順 2、 1の画像 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Microphone Replacement: 手順 3、 2の画像 1 SuperSonic Matrix Mid SC-999 Microphone Replacement: 手順 3、 2の画像 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: 手順 4、 1の画像 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  5. SuperSonic Matrix Mid SC-999 Microphone Replacement: 手順 5、 2の画像 1 SuperSonic Matrix Mid SC-999 Microphone Replacement: 手順 5、 2の画像 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
終わりに
作成者
3人の作成者と共同で作成されました。
Harris Dagha
メンバー登録日: 03/26/15
866 ポイント
7のガイドは作成済み
チーム
Dr Shaverz boyz Dr Shaverz boyz人のメンバー
Community
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 147
