はじめに
The GameDAC control wheel is the component that controls the dial of the GameDAC. This electrical component is called a potentiometer. When replacing the potentiometer, one should be careful of wired connections on the circuit board. Follow this guide to safely replace the potentiometer.
必要な工具と部品
Remove the plastic cover using the iFixit opening tool to pry the cover open.
Insert opening picks to keep the cover open as you work your way around the GameDAC.
Pop the cover off.
5 の人々がこのガイドを完成させました。
3 件のコメント
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
I would like to know too. Cause it failed for me as well!!
