メインコンテンツにスキップ
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
必要な工具と部品
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 手順 1、 3の画像 1 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 手順 1、 3の画像 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: 手順 1、 3の画像 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 2、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 2、 2の画像 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 3、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 3、 2の画像 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 4、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 4、 2の画像 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 5、 1の画像 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 6、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: 手順 6、 2の画像 2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on はんだ付けとはんだ除去の作業ガイド.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Avinash Vadlamudi
メンバー登録日: 01/24/19
451 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
3 件のコメント
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - 返信
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - 返信
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 49
今までの合計 4,644
