メインコンテンツにスキップ
SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement
必要な工具と部品
  1. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: 手順 1、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Ear Cushions: 手順 1、 2の画像 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Headset Circuit Board: 手順 2、 1の画像 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 3、 1の画像 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 4、 1の画像 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement, Microphone Cable: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Pull up on the wires connected to the circuit board using tweezers to remove the circuit board from inside the headset.
  7. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 7、 1の画像 1
    • Desolder the six wired connections on the circuit board.
    • For help desoldering connections, follow this useful guide on はんだ付けとはんだ除去の作業ガイド.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 8、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 8、 2の画像 2
    • Lift up the wire on the rotating wheel with tweezers to move it out of the way of the screws.
    • Remove the two 5mm screws with a Phillips #0 driver head.
  9. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 9、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 9、 2の画像 2
    • Pull out the rotating wheel from the headset casing.
    • Remove the microphone from the casing with the rotator wheel.
    • After removing the rotating wheel, lift the wheel up and use your other hand to feed the microphone through the case.
  10. SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 10、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Microphone Cable Replacement: 手順 10、 2の画像 2
    • Pull the microphone wire out of the wheel.
    • Forcefully removing the microphone from the wheel may break the plastic wheel.
    • Pull the wire and wheel apart to remove the entire component.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Vanessa Beeler
メンバー登録日: 01/24/19
296 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
9 件のコメント
can Ii do this with my Arctis 5?
Vantura - 返信
Ugh! Why do they all fail at mic design so bad? Something that has been mastered for decades. It blows my mind.
Chris - 返信
Is there any place where i can get this cable? I also need a new mic for the wireless pro but steelseries dont sell parts. Somehow it came off and i lost it.
robinmusch - 返信
&&^& my mic died and i don’t have warranty wtf -_-
taps_so - 返信
The left earpiece on mine has a different screw type than phillips for some reason. I think it’s a kind of hex screw but I have hex heads and none worked. Strange that the left and right earpieces use different screws.
Darren Peterson - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 44
過去 30 日: 162
今までの合計 12,557
