メインコンテンツにスキップ
SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement
必要な工具と部品
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: 手順 1、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: 手順 1、 2の画像 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Circuit Board: 手順 2、 1の画像 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 手順 3、 1の画像 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 手順 4、 1の画像 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: 手順 6、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: 手順 6、 2の画像 2
    • Flip the circuit board over and remove the keycap by pulling on it.
  7. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button: 手順 7、 1の画像 1
    • Desolder the wires connecting the button to the circuit board.
    • For help desoldering connections, follow this useful guide on はんだ付けとはんだ除去の作業ガイド.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 手順 8、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: 手順 8、 2の画像 2
    • Desolder the three pins to remove the button from the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kyle Chang
メンバー登録日: 01/24/19
1,152 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
7 件のコメント
Where can you get the replacement switch?
Jason Rosa - 返信
Can you provide any specs for this switch? I’d like to buy the replacement switch before disassembling the headset.
DAA - 返信
I also need to know where to get the replacement switch from !
Trevor Peters - 返信
If anyone wants to try it (I have not), I think the G type switch will work. BUT you will have to find a way to mount it, as it does not have the Metal case for soldering to the PCB.
Searchebay.co.uk for 11 Types, DPDT Self Latching Locking Momentary Push Button PCB SMD Switch 6 Pin
Select Type G
Try at your own risk and good luck
Trevor Peters - 返信
BTW, the size of the switch is 5.8 x 5.8 mm
DAA - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 30
過去 30 日: 167
今までの合計 9,753
