メインコンテンツにスキップ
SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement
必要な工具と部品
  1. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 手順 1、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: 手順 1、 2の画像 2
    • Lift the edge of the cushion and slightly pull out.
    • Work your way around the cushion until it comes off.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 2、 1の画像 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 3、 1の画像 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 4、 1の画像 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 6、 2の画像 1 SteelSeries Arctis Pro Plus GameDAC 3.5mm Headphone Jack Replacement: 手順 6、 2の画像 2
    • Desolder the three connecting audio jack leads from the circuit board.
    • For help desoldering connections, follow this useful guide on はんだ付けとはんだ除去の作業ガイド.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Juan Gonzalez
メンバー登録日: 01/24/19
422 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
コメント 1 件
hey @juangonzal87030 I am unable to take out circuit board out of my Arctic Wireless Pro even even when all the screws are taken out. I am unable to understand what am I missing over here. Can you help
Ashutosh Kumar Singh - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 72
今までの合計 8,839
