メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのSteam Deckを修理する際は、iFixitの修理ガイドをご利用ください。
    • Type 1: M1.6x9; plastic thread forming; 1.6 mm thread diameter; 0.64 mm thread pitch; 9 mm thread length; 2.8 mm head diameter; 0.6 mm head thickness
    • Type 2: M1.6x5; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 5 mm thread length; 2.8 mm head diameter; 0.5 mm head thickness
    • Type 3: M2x3.5; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 3.5 mm thread length; 5 mm head diameter; 0.9 mm head thickness
    • Type 4: M1.6x4.5; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4.5 mm thread length; 3.5 mm head diameter; 0.8 mm head thickness
    • Type 5: M1.6x3; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 3 mm thread length; 2.8 mm head diameter; 0.8 mm head thickness
    • Type 6: M2x2.2; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 2.2 mm thread length; 4.5 mm head diameter; 0.5 mm head thickness
    • Type 7: M1.6x4; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4 mm thread length; 3 mm head diameter; 0.8 mm head thickness
    • Type 8: M1.2x2; machine screw; 1.2 mm thread diameter; 0.25 mm thread pitch; 2 mm thread length; 2.2 mm head diameter; 0.4 mm head thickness
  1. Steam Deck Screw ID, Back cover: 手順 2、 2の画像 1 Steam Deck Screw ID, Back cover: 手順 2、 2の画像 2
    • Type 1: M1.6x9 plastic thread forming screw
    • Type 2: M1.6x5 machine screw
  2. Steam Deck Screw ID, Back cover removed: 手順 3、 2の画像 1 Steam Deck Screw ID, Back cover removed: 手順 3、 2の画像 2
    • Type 3: M2x3.5 machine screw
    • Type 4: M1.5x4.5 plastic thread forming screw
    • Type 5: M1.6x3 machine screw
  3. Steam Deck Screw ID, Motherboard shield removed: 手順 4、 2の画像 1 Steam Deck Screw ID, Motherboard shield removed: 手順 4、 2の画像 2
    • Type 6: M2x2.2 machine screw
  4. Steam Deck Screw ID, Trigger area: 手順 5、 2の画像 1 Steam Deck Screw ID, Trigger area: 手順 5、 2の画像 2
  5. Steam Deck Screw ID, Bumper area: 手順 6、 2の画像 1 Steam Deck Screw ID, Bumper area: 手順 6、 2の画像 2
  6. Steam Deck Screw ID, Trackpad area: 手順 7、 2の画像 1 Steam Deck Screw ID, Trackpad area: 手順 7、 2の画像 2
    • Type 7: M1.6x4 plastic thread forming screw
  7. Steam Deck Screw ID, Midframe: 手順 8、 2の画像 1 Steam Deck Screw ID, Midframe: 手順 8、 2の画像 2
  8. Steam Deck Screw ID, Under display: 手順 9、 2の画像 1 Steam Deck Screw ID, Under display: 手順 9、 2の画像 2
    • Type 8: M1.2x2 machine screw
コメント 1 件
Is there a way to convert these sizes to the ones used in the rest of the guides?
such as: M1.6x4= 4.7mm
Emojitsu Gaming - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 55
過去 30 日: 266
今までの合計 6,380
