はじめに
Inside the earcups there are two foam screens that with time can get dirty and/or degrade.
As reported by Sony's partner Encompass, OEM part numbers are 4-738-572-01 (left) and 4-738-573-01 (right)
Third-party screens are usually sold together with ear cushions.
必要な工具と部品
Insert a plastic spudger between the cushion and the earcup frame
There are six clips that hold the cushion in place, release them moving the spudger around the frame
Cut double-sided tape and place it in the same position of the old screens
Once installed the new screens, reinstall earpad
3 の人々がこのガイドを完成させました。
2件のガイドコメント
Danke! / Thank you!
Ich frage mich nur warum der Schaumstoff die Öffnung (Bild 4) nicht verschließen sollte (reines Interesse)? Hat das eine Auswirkung auf die Funktion des NC? /
I just wonder why the foam should not close the opening (picture 4) (just out of interest)? Does this affect the function of the NC?
Yes, as far as I understood it is necessary for NC and pressure equalization maybe
