メインコンテンツにスキップ
Sony VAIO VPCEE26FX Keyboard Replacement
必要な工具と部品
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 手順 1、 2の画像 1 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 2、 2の画像 1 Sony VAIO VPCEE26FX Keyboard Replacement: 手順 2、 2の画像 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 手順 3、 2の画像 1 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 5、 2の画像 1 Sony VAIO VPCEE26FX Keyboard Replacement: 手順 5、 2の画像 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 6、 2の画像 1 Sony VAIO VPCEE26FX Keyboard Replacement: 手順 6、 2の画像 2
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 7、 1の画像 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: 手順 8、 1の画像 1
    • Lift the keyboard up and away from the computer.
終わりに
作成者
2人の作成者と共同で作成されました。
Christopher Hover
メンバー登録日: 03/21/19
679 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S2G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 16
今までの合計 1,164
