メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Smart Watch SW2 Battery Replacement
必要な工具と部品
  1. Sony Smart Watch SW2 Battery Replacement, Display Assembly: 手順 1、 1の画像 1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Battery Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Battery Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Battery Replacement: 手順 4、 1の画像 1
    • Set aside the detached LCD screen to access the battery.
  5. Sony Smart Watch SW2 Battery Replacement, Battery: 手順 5、 1の画像 1
    • Lift one side of the battery up carefully. There is a thin black circuit adhered to the back of the battery that connects to the motherboard and the charger.
    • The connection is already broken in this image and you will not be able to lift the battery this high.
  6. Sony Smart Watch SW2 Battery Replacement: 手順 6、 1の画像 1
    • Push the black piece down while very carefully pulling the battery off. Work your way around without lifting the black piece up too much.
  7. Sony Smart Watch SW2 Battery Replacement: 手順 7、 1の画像 1
    • Once the battery is free from the frame adhesive, desolder the black and red battery wires.
    • Remove the battery.
終わりに
To reassemble your device, follow these instructions in reverse order after the battery is replaced.
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Vincent Shiue
メンバー登録日: 01/22/18
265 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G5, Freund Spring 2018 IUPUI, Team S1-G5, Freund Spring 2018人のメンバー
IUPUI-FREUND-S18S1G5
3 メンバー
2のガイドは作成済み
3件のガイドコメント
HI
please from where can i get the battery i want new one you know any website sell this battery
thanks
hossamman2014 - 返信
I think AliExpress has some compatible batteries. I may order one too.
S. Pamnco -
Looked replacing battery but when I pushed the assembly free from the case I could see corrosion. Is it worth the trouble?
David Lewis - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 34
今までの合計 5,591
