メインコンテンツにスキップ
Sony SRS-XB43 Motherboard Replacement
必要な工具と部品
  1. Sony SRS-XB43 Motherboard Replacement, Faceplate: 手順 1、 2の画像 1 Sony SRS-XB43 Motherboard Replacement, Faceplate: 手順 1、 2の画像 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Motherboard Replacement: 手順 2、 1の画像 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Motherboard Replacement: 手順 3、 1の画像 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Motherboard Replacement: 手順 4、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 4、 2の画像 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Motherboard Replacement, Battery: 手順 5、 2の画像 1 Sony SRS-XB43 Motherboard Replacement, Battery: 手順 5、 2の画像 2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Motherboard Replacement: 手順 6、 3の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 6、 3の画像 2 Sony SRS-XB43 Motherboard Replacement: 手順 6、 3の画像 3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Motherboard Replacement: 手順 7、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 7、 2の画像 2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Motherboard Replacement: 手順 8、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 8、 2の画像 2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
  9. Sony SRS-XB43 Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Sony SRS-XB43 Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Orient the motherboard chassis towards you for a clear view of connection points.
    • Disconnect both LED ribbon cables on the far right and left of the motherboard by gently pulling them up.
  10. Sony SRS-XB43 Motherboard Replacement: 手順 10、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 10、 2の画像 2
    • Pull the port housing cable up from the middle-back edge of the motherboard.
  11. Sony SRS-XB43 Motherboard Replacement: 手順 11、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 11、 2の画像 2
    • Orient the chassis so that the back of the motherboard where the six buttons are located is facing upwards.
    • Remove the two 10 mm screws that secure the motherboard to its chassis using a Phillips #1 screwdriver.
  12. Sony SRS-XB43 Motherboard Replacement: 手順 12、 2の画像 1 Sony SRS-XB43 Motherboard Replacement: 手順 12、 2の画像 2
    • Gently remove the motherboard from the chassis.
終わりに
作成者
2人の作成者と共同で作成されました。
Isaac Oliveira
メンバー登録日: 10/26/22
267 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022人のメンバー
UMASSD-BOTVIN-F22S3G5
4 メンバー
5のガイドは作成済み
コメント 1 件
Do you sell the motherboard?
Garrick Kidd - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 46
今までの合計 679
