はじめに
This guide will demonstrate how to replace the speaker system of the Sony SRS-X55 portable speaker. Upon the completion of this guide the entire speaker system will be removed and replaced.
必要な工具と部品
Remove the six 9 mm screws on the bottom panel using the Phillips head #2.
Place the tip of the soldering iron against the wire terminals until the connection separates on its own. The three terminal locations are shown.
Reconnect the leads to the proper terminals. Use either of the other speakers as a reference if needed; they will have the same wire configuration.
For step-by-step instructions on soldering check out this link はんだ付けとはんだ除去の作業ガイド.
4 の人々がこのガイドを完成させました。
6 件のコメント
Hello, Thanks for your tuto … Please can you help me to buy a new central loudspeaker … I only found "already used parts" on eBay an would like to buy a new "not used" part ? Thanks in advance for your answer
hi im in the same situation as Pascal I cant find where to buy the 10W bass speaker online.
Steve Chaney
Hi Steve,
I have the same problem. Did you find some 10w bass speaker?
Sven from germany
Tuchplet is damaging and new tuchplet ripleys
