メインコンテンツにスキップ
Sony RM-LVR1 LCD Screen Replacement
必要な工具と部品
  1. Sony RM-LVR1 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 LCD Screen Replacement: 手順 2、 1の画像 1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 手順 3、 2の画像 1 Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 手順 3、 2の画像 2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 LCD Screen Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 LCD Screen Replacement: 手順 6、 1の画像 1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 LCD Screen Replacement: 手順 7、 2の画像 1 Sony RM-LVR1 LCD Screen Replacement: 手順 7、 2の画像 2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 LCD Screen Replacement: 手順 8、 1の画像 1
    • Remove the screen from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Alexander Thomas
メンバー登録日: 09/28/17
265 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team S2-G2, Crane Fall 2017 Eastern Washington University, Team S2-G2, Crane Fall 2017人のメンバー
EWU-CRANE-F17S2G2
3 メンバー
6のガイドは作成済み
4 件のコメント
здорово!
подскажите где купить дисплей?, или его маркировку?. на дисплее ничего не написано, не могу найти.
Александр - 返信
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
Sven van Bellen - 返信
any link to the replacement LCD please?
Bart Ptachowski - 返信
Hi .
search : HD 170 LCD Drift aliexp****
i think it will do the job .
cheers
ruigyl - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 14
今までの合計 496
