メインコンテンツにスキップ
Sony H.ear On 2 Bluetooth Transceiver Replacement
必要な工具と部品
  1. Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 手順 1、 2の画像 1 Sony H.ear On 2 Bluetooth Transceiver Replacement, Ear Cup: 手順 1、 2の画像 2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 2、 2の画像 1 Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 2、 2の画像 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 手順 3、 2の画像 1 Sony H.ear On 2 Bluetooth Transceiver Replacement, Bluetooth Transceiver: 手順 3、 2の画像 2
    • Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
    • Unlike the right ear cup, there is no ribbon cable directly connecting the rest of the headphones to the outer cup.
  4. Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 4、 3の画像 1 Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 4、 3の画像 2 Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 4、 3の画像 3
    • Using the JIS #00 screwdriver, remove the two 6.4 mm screws holding the NFC chip in place over the motherboard.
    • Once the screws are removed, gently turn over the board to the left to expose the soldered connection points.
  5. Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 5、 2の画像 1 Sony H.ear On 2 Bluetooth Transceiver Replacement: 手順 5、 2の画像 2
    • Using a soldering iron, carefully de-solder the two connection points on the NFC chip.
    • Once the solder has completely melted, carefully separate the wires and the NFC chip itself.
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
終わりに
作成者
5人の作成者と共同で作成されました。
Peter Van Ness
メンバー登録日: 04/15/19
147 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S9G11
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 23
今までの合計 1,371
