はじめに
The following steps will outline how to take out a motherboard from the Sony GTK-XB5 and replace it. No tools are needed after disassembly. Before doing anything, be sure to safely discharge the capacitor using this guide.
必要な工具と部品
First, remove the eight screws on the speaker's back panel. These screws should be located on the top and bottom corners of the back, as well as along the sides.
Remove the 7.5 mm Phillips-head screws using a Phillips #1 screwdriver with a J sized head.
Next, remove 4 more 7.5 mm Phillips-head screws on the top part of the speaker (where the power buttons and extra BASS buttons are located). Two of the screws are located on the underside of the handle and are hidden beneath black rubber covers. Remove the covers and use a Phillips #1 screwdriver to unscrew the screws.
The remaining two 7.5 mm Phillips-head screws are located on the base of the indented section of the speaker, pictured here. They are also hidden beneath black rubber covers. Repeat same process in removing the screws.
Additionally, the sides need to be taken apart. You will need to take out 4 additional 7.5 mm Phillips-head screws on either side. These screws are located beneath larger grey pads with adhesive on them at the side corners of your speaker.
Remove the pads slowly, as the adhesive makes them tougher to remove and you do not want to rip them.
Use an opening tool to help take out the side shell from the rest of the speaker.
Find the large green motherboard, located underneath the top plastic housing of the speaker.
6 の人々がこのガイドを完成させました。
3 件のコメント
could you tell me were I can get this replacement board, mine no longer works and would like to replace it. thank you
for reply my email is myklthebrain@hotmail.com thanks you kindly.
Mike MacI. - 返信
You can buy it here:
