メインコンテンツにスキップ
Sony FDL-220R Watchman Battery and Battery Contacts Replacement
必要な工具と部品
  1. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: 手順 1、 2の画像 1 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove battery cover and batteries: 手順 1、 2の画像 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts in battery compartment: 手順 2、 1の画像 1
    • Inspect battery contacts for any signs of damage.
    • Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
  3. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: 手順 3、 2の画像 1 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove screws: 手順 3、 2の画像 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  4. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: 手順 4、 2の画像 1 Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Remove back casing: 手順 4、 2の画像 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  5. Sony FDL-220R Watchman Battery and Battery Contacts Replacement, Inspect battery contacts on inside of back cover: 手順 5、 1の画像 1
    • Inspect the two small springs on the back of the battery compartment.
    • Clean contacts with a solution of warm water and baking soda if there is corrosion.
終わりに
作成者
2人の作成者と共同で作成されました。
Sam Putnam
メンバー登録日: 10/22/14
484 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 434
