メインコンテンツにスキップ
Sony DualSense Controller Rear Case Replacement
必要な工具と部品
  1. Sony DualSense Controller Rear Case Replacement, Unclip the right end of the middle trim: 手順 1、 2の画像 1 Sony DualSense Controller Rear Case Replacement, Unclip the right end of the middle trim: 手順 1、 2の画像 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: 手順 2、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: 手順 2、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: 手順 2、 3の画像 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Rear Case Replacement, Unclip the left end of the middle trim: 手順 3、 2の画像 1 Sony DualSense Controller Rear Case Replacement, Unclip the left end of the middle trim: 手順 3、 2の画像 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: 手順 4、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: 手順 4、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: 手順 4、 3の画像 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Rear Case Replacement, Remove the middle trim: 手順 5、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Remove the middle trim: 手順 5、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Remove the middle trim: 手順 5、 3の画像 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Rear Case Replacement, Remove the L1 button: 手順 6、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Remove the L1 button: 手順 6、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Remove the L1 button: 手順 6、 3の画像 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Rear Case Replacement, Remove the R1 button: 手順 7、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Remove the R1 button: 手順 7、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Remove the R1 button: 手順 7、 3の画像 3
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Rear Case Replacement, Remove the rear case screws: 手順 8、 2の画像 1 Sony DualSense Controller Rear Case Replacement, Remove the rear case screws: 手順 8、 2の画像 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Rear Case Replacement: 手順 9、 2の画像 1 Sony DualSense Controller Rear Case Replacement: 手順 9、 2の画像 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Rear Case Replacement, Separate the rear case: 手順 10、 3の画像 1 Sony DualSense Controller Rear Case Replacement, Separate the rear case: 手順 10、 3の画像 2 Sony DualSense Controller Rear Case Replacement, Separate the rear case: 手順 10、 3の画像 3
    • Be gently when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Rear Case Replacement: 手順 11、 3の画像 1 Sony DualSense Controller Rear Case Replacement: 手順 11、 3の画像 2 Sony DualSense Controller Rear Case Replacement: 手順 11、 3の画像 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Rear Case Replacement: 手順 12、 3の画像 1 Sony DualSense Controller Rear Case Replacement: 手順 12、 3の画像 2 Sony DualSense Controller Rear Case Replacement: 手順 12、 3の画像 3
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Rear Case Replacement: 手順 13、 2の画像 1 Sony DualSense Controller Rear Case Replacement: 手順 13、 2の画像 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Rear Case Replacement, Remove the rear case: 手順 14、 1の画像 1
    • Remove the rear case.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
83,715 ポイント
290のガイドは作成済み
コメント 1 件
Where do i get fitting rear cases?
Zoonk Dng - 返信
コメントを追加
統計データ:
過去 24時間: 29
過去 7 日: 128
過去 30 日: 524
今までの合計 18,308
