メインコンテンツにスキップ
Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, LCD Screen: 手順 1、 1の画像 1
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: 手順 2、 2の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: 手順 2、 2の画像 2
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 3、 2の画像 2
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 4、 2の画像 2
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 5、 1の画像 1
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 6、 2の画像 2
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
  7. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: 手順 7、 2の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: 手順 7、 2の画像 2
    • Remove the screws from the metal board using the Phillips #00 screwdriver.
    • Pop apart the metal board using the plastic opening tool.
    • Peel apart the black tape from the flash bulb.
    • Avoid touching the bulb as it will burn or shock if touched.
  8. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 8、 3の画像 1 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 8、 3の画像 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 8、 3の画像 3
    • Pry open the remaining covers of the camera using the plastic opening tool.
    • Some parts may fall out during this process.
  9. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 9、 1の画像 1
    • Unscrew the one screw from the motherboard.
    • Disconnect the two links from the camera unit to the motherboard.
  10. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 手順 10、 1の画像 1
    • Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
kyle
メンバー登録日: 02/05/15
424 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 28
今までの合計 1,336
