この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Make sure you have all of the requisite tools on hand before beginning to replace the flash bulb and its casing.
必要な工具と部品
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Turn the camera so the back is facing you.
Remove the 2.5mm Philips #0 screw at the top of the camera.
ある他の人がこのガイドを完成しました。
