Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
Remove the two 2.5mm Phillips #0 screws.
You may have to remove the screws with a pair of tweezers when the screws are almost out.
Turn the camera so the right side faces you.
Turn camera so that the front of the camera is facing you.
Pull the front casing directly away from the camera.
The right side panel may fall off when you take the front panel off.
Tilt top casing up and towards you.
Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
