On the right side of the camera, remove the two silver screws using the screwdriver.
The picture shows the lens facing away from you and the LCD screen facing you.
On the left side of the camera, remove the two silver screws using the screwdriver.
Keep track of the small screws that you remove.
Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Be cautious not to break the fragile pieces or scratch the LCD screen.
The last screw is in the bottom left corner of the camera's right side.
Using a screwdriver, remove the last screw holding the LCD/control panel to the rest of the camera on the right-hand side.
It is crucial for reassembly to track which screws were removed from which holes.
At this point, all screws on the left and right sides of the camera should be removed.
Paying careful attention to the right side's electrical wiring, gently pull the left side of the LCD plate away from the rest of the camera.
DO NOT detach the electrical wiring connecting the right side of the LCD and the camera.
This picture is used to identify the action required to release the electrical ribbons, but not the proper location for this step.
This step applies to the larger electrical ribbon connecting the LCD screen and circuit board.
Using a spudger, wedge the flat-tipped end between the black bar and the circuit board.
Carefully lift the black bar into the vertical position.
この手順で使用する道具:
購入する
After raising the black bar, the electrical ribbon should be free from its port.
Use tweezers to carefully pull the larger electrical ribbon from its circuit board port.
The smaller electrical ribbon, to the left of the larger ribbon, does not have a black bar securing it in place.
Use tweezers to pull the smaller electrical ribbon carefully from its circuit board port.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
