メインコンテンツにスキップ
Sony Cyber-shot DSC-HX300 Motherboard Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 2、 1の画像 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 3、 1の画像 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 手順 5、 3の画像 1 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 手順 5、 3の画像 2 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 手順 5、 3の画像 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 6、 2の画像 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 7、 1の画像 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 8、 3の画像 1 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 8、 3の画像 2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 8、 3の画像 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 9、 2の画像 1 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 手順 9、 2の画像 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
    Would you know how do I remove the lens parts? My zoom is broken and I can find new parts on ebay, but I don't know how to remove and replace it. Thanks!
    flaviowolff - 返信
終わりに
作成者
6人の作成者と共同で作成されました。
Elizabeth Surface
メンバー登録日: 08/26/15
1,465 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G6
4 メンバー
18のガイドは作成済み
3 件のコメント
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
Erik Mourik - 返信
Where can you order a motherboard?
Astrid - 返信
That ist what i need to know too. Where can i order a Motherboard?
Jürgen Frömmert - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 25
今までの合計 2,892
