メインコンテンツにスキップ
Sony Cyber-Shot DSC-TX9 Card Reader Replacement
必要な工具と部品
  1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 手順 1、 3の画像 1 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 手順 1、 3の画像 2 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 2、 2の画像 1 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 2、 2の画像 2
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 3、 1の画像 1
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 4、 2の画像 1 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 4、 2の画像 2
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (ケーブルコネクタの識別と接続の外し方) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 手順 5、 3の画像 1 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 手順 5、 3の画像 2 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: 手順 5、 3の画像 3
    • Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
    • Detach the smaller ribbon cables by sliding them out.
    • Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Detach the ribbon cables slowly and carefully or they will rip.
  6. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 6、 2の画像 1 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: 手順 6、 2の画像 2
    • Carefully remove the Memory card circuit board.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
終わりに
作成者
2人の作成者と共同で作成されました。
Yegor Shea
メンバー登録日: 03/26/17
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G3, Julie Spring 2017 UMass Dartmouth, Team S4-G3, Julie Spring 2017人のメンバー
UMASSD-JULIE-S17S4G3
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 15
今までの合計 379
