はじめに
Installing a new speaker fairly simple as it only involves opening the device casing and then removing the broken speaker.
必要な工具と部品
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
この手順で使用する道具:Tweezers$4.99
Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
Remove the tape holding speaker wire by peeling it away.
終わりに
