はじめに
手順 1 に進む ↓If your device is not holding a charge or simply will not turn on, it is possible that you need to replace the battery. This easy guide will take you through the necessary steps in order to remove the battery so you may install a new one.
必要な工具と部品
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
4 の人々がこのガイドを完成させました。
2件のガイドコメント
Hi, this is really helpful, thank you.
Ismein display Se Le Gaye to kaise Sahi Karen
Nihal Alee - 返信 共有
