メインコンテンツにスキップ
Sony BDP-s7200 Power Supply Board Replacement
必要な工具と部品
  1. Sony BDP-s7200  Power Supply Board Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Power Supply Board Replacement: 手順 2、 2の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 2、 2の画像 2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Power Supply Board Replacement: 手順 3、 2の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 3、 2の画像 2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Power Supply Board Replacement: 手順 4、 1の画像 1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: 手順 5、 3の画像 1 Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: 手順 5、 3の画像 2 Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: 手順 5、 3の画像 3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Power Supply Board Replacement: 手順 6、 2の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 6、 2の画像 2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Power Supply Board Replacement: 手順 7、 3の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 7、 3の画像 2 Sony BDP-s7200  Power Supply Board Replacement: 手順 7、 3の画像 3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Power Supply Board Replacement: 手順 8、 2の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 8、 2の画像 2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Power Supply Board Replacement, Power Supply Board: 手順 9、 1の画像 1
    • Remove the ribbon cables that connect to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Power Supply Board Replacement: 手順 10、 1の画像 1
    • Remove the power supply board cable connected to the motherboard.
  11. Sony BDP-s7200  Power Supply Board Replacement: 手順 11、 1の画像 1
    • Remove the 2 screws using the Phillips #2 screwdriver
    • Slide the power cord out of it's slot in the frame.
  12. Sony BDP-s7200  Power Supply Board Replacement: 手順 12、 2の画像 1 Sony BDP-s7200  Power Supply Board Replacement: 手順 12、 2の画像 2
    • Remove the Power Supply Board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Erik Preston
メンバー登録日: 01/16/20
412 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 868
