メインコンテンツにスキップ
Sony BDP-S3500 Motherboard Replacement
必要な工具と部品
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: 手順 1、 2の画像 1 Sony BDP-S3500 Motherboard Replacement, Front Panel: 手順 1、 2の画像 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: 手順 2、 1の画像 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: 手順 3、 2の画像 1 Sony BDP-S3500 Motherboard Replacement: 手順 3、 2の画像 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: 手順 4、 2の画像 1 Sony BDP-S3500 Motherboard Replacement, Disk Drive: 手順 4、 2の画像 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: 手順 5、 2の画像 1 Sony BDP-S3500 Motherboard Replacement: 手順 5、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: 手順 6、 2の画像 1 Sony BDP-S3500 Motherboard Replacement: 手順 6、 2の画像 2
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Sony BDP-S3500 Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: 手順 8、 3の画像 1 Sony BDP-S3500 Motherboard Replacement: 手順 8、 3の画像 2 Sony BDP-S3500 Motherboard Replacement: 手順 8、 3の画像 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: 手順 9、 1の画像 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Michael Meissner
メンバー登録日: 01/22/20
220 ポイント
2のガイドは作成済み
チーム
York University, Team S8-G4, Turner Winter 2020 York University, Team S8-G4, Turner Winter 2020人のメンバー
YORK-TURNER-W20S8G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 489
