はじめに
This is a guide to remove the front panel assembly of the Sony BDP S3500.
Be sure to review the troubleshooting guide, as most of the time the problems are due malfunctioning software rather than it being a hardware issue.
This guide will show you how to safely remove the front panel assembly without damaging the other components.
必要な工具と部品
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
2 の人々がこのガイドを完成させました。
