メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony BDP-BX620 Bluetooth Module Replacement
必要な工具と部品
  1. Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: 手順 1、 2の画像 1 Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: 手順 1、 2の画像 2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
    FixBotに聞いてみる
    コメントを追加
  2. Sony BDP-BX620 Bluetooth Module Replacement: 手順 2、 2の画像 1 Sony BDP-BX620 Bluetooth Module Replacement: 手順 2、 2の画像 2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
    FixBotに聞いてみる
    コメントを追加
  3. Sony BDP-BX620 Bluetooth Module Replacement: 手順 3、 3の画像 1 Sony BDP-BX620 Bluetooth Module Replacement: 手順 3、 3の画像 2 Sony BDP-BX620 Bluetooth Module Replacement: 手順 3、 3の画像 3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
    FixBotに聞いてみる
    コメントを追加
  4. Sony BDP-BX620 Bluetooth Module Replacement, Port Board: 手順 4、 2の画像 1 Sony BDP-BX620 Bluetooth Module Replacement, Port Board: 手順 4、 2の画像 2
    • Now, spot the large ribbon cable that connects between the motherboard and the port board.
    • Remove the cable by pulling upwards.
    • Be careful when pulling upwards on the ribbon cable. Too much force can cause it to rip.
    FixBotに聞いてみる
    コメントを追加
  5. Sony BDP-BX620 Bluetooth Module Replacement: 手順 5、 1の画像 1
    • Use your Phillips screwdriver to take out the silver screw holding in the port board.
    FixBotに聞いてみる
    コメントを追加
  6. Sony BDP-BX620 Bluetooth Module Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Now use the tweezers to unclip the portboard on the side.
    FixBotに聞いてみる
    コメントを追加
  7. Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: 手順 7、 2の画像 1 Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: 手順 7、 2の画像 2
    • Now, pull the small ribbon cable that connects between the motherboard and the Bluetooth module.
    • Be careful to not pull too hard or the ribbon cable will rip.
    FixBotに聞いてみる
    コメントを追加
  8. Sony BDP-BX620 Bluetooth Module Replacement: 手順 8、 1の画像 1
    • Use your Phillips screwdriver to remove the silver screw holding the Bluetooth module in place.
    FixBotに聞いてみる
    コメントを追加
  9. Sony BDP-BX620 Bluetooth Module Replacement: 手順 9、 1の画像 1
    • Lift to remove the bluetooth module from the device.
    • To prevent damage, always hold it on the sides.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Zachery Zavala
メンバー登録日: 10/05/16
175 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016人のメンバー
USFT-LACY-F16S1G6
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 540
