メインコンテンツにスキップ
Sony BDP-BX510 Port Board Replacement
必要な工具と部品
  1. Sony BDP-BX510 Port Board Replacement, Outer Cover: 手順 1、 1の画像 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Port Board Replacement: 手順 2、 2の画像 1 Sony BDP-BX510 Port Board Replacement: 手順 2、 2の画像 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Port Board Replacement: 手順 3、 2の画像 1 Sony BDP-BX510 Port Board Replacement: 手順 3、 2の画像 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Port Board Replacement: 手順 4、 3の画像 1 Sony BDP-BX510 Port Board Replacement: 手順 4、 3の画像 2 Sony BDP-BX510 Port Board Replacement: 手順 4、 3の画像 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Port Board Replacement: 手順 5、 1の画像 1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Port Board Replacement, Port Board: 手順 6、 1の画像 1
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Port Board Replacement: 手順 7、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Port Board Replacement: 手順 8、 1の画像 1
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Port Board Replacement: 手順 9、 1の画像 1
    • Remove the port board by simply pulling it away from the device.
終わりに
作成者
1人の作成者と共同作成されました。
Niki Ngosi
メンバー登録日: 01/19/20
375 ポイント
3のガイドは作成済み
チーム
York University, Team S1-G10, Woodhouse Winter 2020 York University, Team S1-G10, Woodhouse Winter 2020人のメンバー
YORK-WOODHOUSE-W20S1G10
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 130
