メインコンテンツにスキップ
Sony α6500 Memory Card Reader Replacement
必要な工具と部品
  1. Sony α6500 Memory Card Reader Replacement, Battery: 手順 1、 1の画像 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Memory Card Reader Replacement: 手順 2、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 2、 2の画像 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Memory Card Reader Replacement: 手順 3、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 3、 2の画像 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Memory Card Reader Replacement: 手順 4、 1の画像 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Memory Card Reader Replacement, Top Assembly: 手順 5、 2の画像 1 Sony α6500 Memory Card Reader Replacement, Top Assembly: 手順 5、 2の画像 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Memory Card Reader Replacement: 手順 6、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 6、 2の画像 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Memory Card Reader Replacement: 手順 7、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 7、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 7、 3の画像 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Memory Card Reader Replacement: 手順 8、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 8、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 8、 3の画像 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Memory Card Reader Replacement: 手順 9、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 9、 2の画像 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Memory Card Reader Replacement: 手順 10、 1の画像 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Memory Card Reader Replacement: 手順 11、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 11、 2の画像 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Memory Card Reader Replacement: 手順 12、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 12、 2の画像 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Memory Card Reader Replacement: 手順 13、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 13、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 13、 3の画像 3
    この手順で使用する道具:
    購入する
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Memory Card Reader Replacement: 手順 14、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 14、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 14、 3の画像 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Memory Card Reader Replacement: 手順 15、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 15、 2の画像 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Memory Card Reader Replacement: 手順 16、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 16、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 16、 3の画像 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Memory Card Reader Replacement: 手順 17、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 17、 2の画像 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Memory Card Reader Replacement: 手順 18、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 18、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 18、 3の画像 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Memory Card Reader Replacement: 手順 19、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 19、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 19、 3の画像 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Memory Card Reader Replacement: 手順 20、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 20、 2の画像 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
  21. Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: 手順 21、 3の画像 1 Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: 手順 21、 3の画像 2 Sony α6500 Memory Card Reader Replacement, Viewfinder Glass: 手順 21、 3の画像 3
    • From the top of the camera remove one 4mm JIS 00 screw.
    • Remove one 5mm JIS 00 screw and the plastic bushing around it.
    • Remove the viewfinder's protective cover.
  22. Sony α6500 Memory Card Reader Replacement: 手順 22、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 22、 2の画像 2
    • Use the spudger to pry the light sensor off the side of the viewfinder.
    • When prying off the sensor, bend it out from the bottom.
    • Remove one 2.5mm JIS 000 screw on the side of the viewfinder to release it.
  23. Sony α6500 Memory Card Reader Replacement: 手順 23、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 23、 2の画像 2
    • Lift the viewfinder out and flip up the tab to release the wire ribbon where it is connected to the motherboard.
  24. Sony α6500 Memory Card Reader Replacement, Motherboard: 手順 24、 3の画像 1 Sony α6500 Memory Card Reader Replacement, Motherboard: 手順 24、 3の画像 2 Sony α6500 Memory Card Reader Replacement, Motherboard: 手順 24、 3の画像 3
    • Remove two 2.5mm JIS 00 screws from the left side and bottom of the copper shielding.
    • Remove two 2mm JIS 000 screws from the right side of the copper shielding.
    • Pull the entire copper shielding piece off.
    • When replacing the shielding, make sure to position the wire ribbon slot under the tabs designed to hold it down.
  25. Sony α6500 Memory Card Reader Replacement: 手順 25、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 25、 2の画像 2
    • You have now accessed the motherboard. The next step is to remove all the wire ribbons attached to it.
    • Remove one 4mm JIS 00 screw holding down a plastic spacer on the bottom left of the motherboard.
  26. Sony α6500 Memory Card Reader Replacement: 手順 26、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 26、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 26、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to carefully pull out the first wire ribbon on the left side of the motherboard.
    • Use the spudger to flip up the tab locking in the wire ribbons at the bottom of the motherboard, then pull them out with tweezers.
  27. Sony α6500 Memory Card Reader Replacement: 手順 27、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 27、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 27、 3の画像 3
    • Carefully use tweezers to remove four wire ribbons on the right side of the motherboard.
    • Remove the last two wire ribbons on the top of the motherboard by flipping up the locking tab and pulling them out.
    • Pull the blue coaxial cable up off the board.
  28. Sony α6500 Memory Card Reader Replacement: 手順 28、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 28、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 28、 3の画像 3
    • Remove one 4mm JIS 00 screw from the upper right of the motherboard and another from the far left.
    • Remove the plastic housing for the power and HDMI ports.
  29. Sony α6500 Memory Card Reader Replacement: 手順 29、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 29、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 29、 3の画像 3
    • The flash capacitors connected to the yellow wire harness have dangerous amounts of stored charge. You must safely discharge them before continuing. Use a Capacitor Discharging Tool to do so.
    • Grasp the motherboard from the sides and lift it up. It is still connected by two wires on the bottom right side.
    • Pull the wire ribbon on the underside off with tweezers.
    • After you have discharged the capacitor, pull the yellow wire harness out using tweezers.
  30. Sony α6500 Memory Card Reader Replacement: 手順 30、 1の画像 1
    • Disconnect the wire ribbon connecting the power port to the board.
  31. Sony α6500 Memory Card Reader Replacement, Memory Card Reader: 手順 31、 1の画像 1
    • Unplug the small ribbon located underneath the ON/OFF button and detach the button assembly from the camera.
  32. Sony α6500 Memory Card Reader Replacement: 手順 32、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 32、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 32、 3の画像 3
    • Remove one 2.5mm JIS 000 screw from the right side of the camera grip.
    • Remove a 4mm JIS 00 screw from the front of the grip and a 2.5mm JIS 00 screw from the left side.
  33. Sony α6500 Memory Card Reader Replacement: 手順 33、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 33、 2の画像 2
    • Flip the black capacitor mount up and remove the 2.5mm JIS 00 screw located directly underneath it.
  34. Sony α6500 Memory Card Reader Replacement: 手順 34、 2の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 34、 2の画像 2
    • Carefully remove the small ribbon where the ON/OFF button used to be.
    • Remove the 4mm JIS 00 screw found directly underneath the small ribbon.
  35. Sony α6500 Memory Card Reader Replacement: 手順 35、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 35、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 35、 3の画像 3
    • Remove the 5mm JIS 00 screw just to the left of the base of the battery compartment.
    • With this screw gone, loosen, but do not remove, the black plastic frame on top of the battery compartment.
  36. Sony α6500 Memory Card Reader Replacement: 手順 36、 3の画像 1 Sony α6500 Memory Card Reader Replacement: 手順 36、 3の画像 2 Sony α6500 Memory Card Reader Replacement: 手順 36、 3の画像 3
    この手順で使用する道具:
    購入する
    • It may be a challenge to remove the SD card reader since it has to be maneuvered out from between other components which have not been removed.
    • Carefully loosen the silver battery compartment from the body of the camera.
    • Use tweezers to remove the sd card slot located adjacent to the battery compartment.
終わりに
作成者
6人の作成者と共同で作成されました。
Jackson Furie
メンバー登録日: 10/10/19
807 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S11-G5, Regan Fall 2019 Cal Poly, Team S11-G5, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S11G5
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 82
今までの合計 3,808
