メインコンテンツにスキップ
Sony α6500 LCD Screen Replacement
必要な工具と部品
  1. Sony α6500 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 LCD Screen Replacement: 手順 2、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 2、 2の画像 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 LCD Screen Replacement: 手順 3、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 3、 2の画像 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the released battery from the compartment.
  5. Sony α6500 LCD Screen Replacement, LCD Screen: 手順 5、 3の画像 1 Sony α6500 LCD Screen Replacement, LCD Screen: 手順 5、 3の画像 2 Sony α6500 LCD Screen Replacement, LCD Screen: 手順 5、 3の画像 3
    • To access the LCD assembly we need to remove the screws attaching its hinge to the camera body.
    • Remove four 3mm JIS 000 screws.
    • Remove one 3mm JIS 00 screw.
    • After dismounting the screen hinge be careful to not tear the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 LCD Screen Replacement: 手順 6、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 6、 2の画像 2
    • Remove the screen hinge from the camera.
    • Be careful to not tear the black flat cable connecting the lcd screen to the main body of the camera. This particular camera's cable has been cut for demonstration purposes.
  7. Sony α6500 LCD Screen Replacement: 手順 7、 1の画像 1
    • Flip the LCD screen up.
    • Remove two 2mm JIS 000 screws on the bottom edge.
  8. Sony α6500 LCD Screen Replacement: 手順 8、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 8、 2の画像 2
    • Flip the LCD screen down to access the back side.
    • Remove two 2mm JIS 000 screws to release the back panel of the screen.
  9. Sony α6500 LCD Screen Replacement: 手順 9、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 9、 2の画像 2
    • Use the opening tool to pry open the back panel.
    • Remove the black plastic spacer laying on top of the circuit board.
  10. Sony α6500 LCD Screen Replacement: 手順 10、 2の画像 1 Sony α6500 LCD Screen Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    • Carefully unplug the three wire ribbons from the circuit board with tweezers.
    • Likely you will need to wiggle the ribbons for a while before they come loose.
    • The ribbons can rip very easily, grasp the black plastic with the tweezers, on the two top ribbons, not the orange wires.
  11. Sony α6500 LCD Screen Replacement: 手順 11、 3の画像 1 Sony α6500 LCD Screen Replacement: 手順 11、 3の画像 2 Sony α6500 LCD Screen Replacement: 手順 11、 3の画像 3
    • Slide the spudger around all sides of the screen's plastic frame, gently breaking the adhesive.
    • Remove the screen from the camera by prying it out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Micah Fitzgerald
メンバー登録日: 10/03/19
644 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S11-G5, Regan Fall 2019 Cal Poly, Team S11-G5, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S11G5
5 メンバー
14のガイドは作成済み
2件のガイドコメント
Hello, do you have an updated link with a currently available lcd screen replacement part?
JRS - Joe’s Random Stuff - 返信
Can I use an a6500 screen to replace an a6600 screen? Are they interchangeable?
Connor Snyder - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 78
今までの合計 3,501
