はじめに
The LED Lights shows if the device you are charging is charged and if the CLASSIC2 is charging itself. Replacing the LED lights requires soldering. If needed guides on soldering are found on iFixit's website. はんだ付けとはんだ除去の作業ガイド
必要な工具と部品
Turn off the device by pressing on the clear power button behind the device.
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
