メインコンテンツにスキップ
Skytex SP728 Battery Replacement
必要な工具と部品
  1. Skytex SP728 Battery  Replacement, Case: 手順 1、 1の画像 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Battery  Replacement: 手順 2、 1の画像 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Battery  Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Battery  Replacement: 手順 4、 1の画像 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Battery  Replacement, Battery: 手順 5、 1の画像 1
    • Remove the yellow and black tape around the battery very carefully
  6. Skytex SP728 Battery  Replacement: 手順 6、 2の画像 1 Skytex SP728 Battery  Replacement: 手順 6、 2の画像 2
    • Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
    • Follow the link below for additional soldering information はんだ付けとはんだ除去の作業ガイド
    • Soldering uses heat so make sure you are careful while doing it. Also, excessive heat can damage the components. So do not apply the soldering iron on a component for extended periods of time.
  7. Skytex SP728 Battery  Replacement: 手順 7、 1の画像 1
    • Using the plastic opening tool, lift up the battery from right edge and set aside.
    • Make sure that you take the battery out very carefully without bending it or damaging it as it contains toxic chemicals.
    • While soldering the wires for the new battery, remember that the red wire has to be connected to the positive terminal and the black wire has to be connected to the negative terminal.
終わりに
To reassemble your device with a new battery, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Galika Adhikari
メンバー登録日: 01/21/15
248 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G1
4 メンバー
11のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 754
