メインコンテンツにスキップ
Skullcandy Hesh 3 Auxiliary Port Replacement
必要な工具と部品
  1. Skullcandy Hesh 3 Auxiliary Port Replacement, Auxiliary Port: 手順 1、 3の画像 1 Skullcandy Hesh 3 Auxiliary Port Replacement, Auxiliary Port: 手順 1、 3の画像 2 Skullcandy Hesh 3 Auxiliary Port Replacement, Auxiliary Port: 手順 1、 3の画像 3
    • Start by removing the earmuffs on the speaker side with the charging port. Gently pull from any point of the ear cushion, while also holding on to the base of the speaker.
    • Use a Phillips #00 screwdriver to remove all four 4.0 mm screws securing the faceplate.
    • Remove the faceplate gently without pulling off the wires attached to the speaker and faceplate.
  2. Skullcandy Hesh 3 Auxiliary Port Replacement: 手順 2、 2の画像 1 Skullcandy Hesh 3 Auxiliary Port Replacement: 手順 2、 2の画像 2
    • Use a soldering iron to heat up the solder at the points where the red, yellow, and black battery cables connect until they detach from the board.
    • Detach the connector on the side of the headphone cup to disconnect the red and black cables (next to the battery cables) from the headphones.
    • Slide the motherboard out of the headphone cup and flip it over.
    • Careful that you don't rip any of the remaining soldered connections (like the speaker connections for example.)
  3. Skullcandy Hesh 3 Auxiliary Port Replacement: 手順 3、 2の画像 1 Skullcandy Hesh 3 Auxiliary Port Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to hold the aux port in place, and use a soldering iron to desolder the aux port points.
    • Use tweezers to remove the aux port.
    • Before attaching the new aux port, make sure to clean the previous spot, and remove any residue of adhesive using a connector conditioner and detailing brush.
終わりに
作成者
4人の作成者と共同で作成されました。
Emma Lyman
メンバー登録日: 01/17/23
385 ポイント
4のガイドは作成済み
チーム
Linn Benton Community College, Team 1-3, Karnes Winter 2023 Linn Benton Community College, Team 1-3, Karnes Winter 2023人のメンバー
LBCC-KARNES-W23S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 17
過去 30 日: 40
今までの合計 180
