メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shure SM58 XLR Connector Wire Repair
必要な工具と部品
    1. Shure SM58 XLR Connector Wire Repair, XLR Microphone Connector Disassembly: 手順 1、 1の画像 1
      • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
      • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
      • Once the screw stops, do not try to loosen it further.
      FixBotに聞いてみる
      コメントを追加
    2. Shure SM58 XLR Connector Wire Repair: 手順 2、 1の画像 1
      • Plug an XLR cable into the loose connector.
      • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
      FixBotに聞いてみる
      コメントを追加
    1. Shure SM58 XLR Connector Wire Repair, Shure SM58 XLR Connector Wire Repair: 手順 3、 1の画像 1
      • If the wire is not exposed from the insulation, strip the broken wire.
      FixBotに聞いてみる
      コメントを追加
    2. Shure SM58 XLR Connector Wire Repair: 手順 4、 1の画像 1
      • Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
      • Connect the red wire to Pin 3 and the blue wire to Pin 2.
      • Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
      FixBotに聞いてみる
      コメントを追加
    3. Shure SM58 XLR Connector Wire Repair: 手順 5、 1の画像 1
      • Clamps are helpful for this step.
      • In one hand, hold the solder. In the other, hold your soldering iron.
      • Touch both the soldering iron and the solder to the contact point. The solder should melt and create a connection between the wire and the microphone connector.
      FixBotに聞いてみる
      コメントを追加
    4. Shure SM58 XLR Connector Wire Repair: 手順 6、 1の画像 1
      • Remove the solder and then the soldering iron from the contact point.
      • If you remove the soldering iron first, the solder may become stuck to the contact point.
      • Let the wire cool for 30 seconds or so.
      • If the wire is not completely connected repeat steps 2 through 5.
      FixBotに聞いてみる
      コメントを追加
    5. Shure SM58 XLR Connector Wire Repair: 手順 7、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
終わりに
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
nat coll
メンバー登録日: 09/27/12
859 ポイント
14のガイドは作成済み
チーム
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G53
5 メンバー
88のガイドは作成済み
9件のガイドコメント
Many thanks. Very helpful.
Namron - 返信 共有
Yes I'm glad it was so simple and quick to fix my mic!
heyaly - 返信 共有
Red wire to pin 3? Seems to go against the pin 2 hot method?
Jim - 返信 共有
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Daniel Berger - 返信 共有
Świetna strona. Brawo.
Kazimierz Serafin - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 153
今までの合計 32,173
