メインコンテンツにスキップ
Shure SM58 XLR Microphone Connector Installation Replacement
必要な工具と部品
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: 手順 1、 1の画像 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: 手順 2、 1の画像 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: 手順 3、 1の画像 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
終わりに
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Ronald Lam
メンバー登録日: 09/27/12
311 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G53
5 メンバー
20のガイドは作成済み
7 件のコメント
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - 返信
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - 返信
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - 返信
Are the threads on your screw stripped?
Daniel Berger - 返信
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 10,611
