メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sharper Image iPulse SI325 LED Lights Replacement
必要な工具と部品
  1. Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: 手順 1、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: 手順 1、 2の画像 2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 LED Lights Replacement: 手順 2、 3の画像 1 Sharper Image iPulse SI325 LED Lights Replacement: 手順 2、 3の画像 2 Sharper Image iPulse SI325 LED Lights Replacement: 手順 2、 3の画像 3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 LED Lights Replacement: 手順 3、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement: 手順 3、 2の画像 2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
  4. Sharper Image iPulse SI325 LED Lights Replacement, Speakers: 手順 4、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement, Speakers: 手順 4、 2の画像 2
    • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
    • Wiggling the connector back and forth as you pull will make removal easier.
  5. Sharper Image iPulse SI325 LED Lights Replacement: 手順 5、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement: 手順 5、 2の画像 2
    • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
  6. Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: 手順 6、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: 手順 6、 2の画像 2
    • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
    • Slowly lift the circuit board out of the front cover and place the cover out of the way.
  7. Sharper Image iPulse SI325 LED Lights Replacement: 手順 7、 2の画像 1 Sharper Image iPulse SI325 LED Lights Replacement: 手順 7、 2の画像 2
    • Remove the solder connecting the LED light that needs replacement.
終わりに
作成者
5人の作成者と共同で作成されました。
Melissa Pasa
メンバー登録日: 10/13/13
701 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G33
4 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 63
今までの合計 640
