メインコンテンツにスキップ
Shark NV352 Roller Brush Motor Replacement
必要な工具と部品
  1. Shark NV352 Roller Brush Motor Replacement, Roller Brush: 手順 1、 2の画像 1 Shark NV352 Roller Brush Motor Replacement, Roller Brush: 手順 1、 2の画像 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Motor Replacement: 手順 2、 1の画像 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Motor Replacement: 手順 3、 2の画像 1 Shark NV352 Roller Brush Motor Replacement: 手順 3、 2の画像 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Motor Replacement: 手順 4、 2の画像 1 Shark NV352 Roller Brush Motor Replacement: 手順 4、 2の画像 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Motor Replacement: 手順 5、 2の画像 1 Shark NV352 Roller Brush Motor Replacement: 手順 5、 2の画像 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Motor Replacement: 手順 6、 2の画像 1 Shark NV352 Roller Brush Motor Replacement: 手順 6、 2の画像 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Motor Replacement: 手順 7、 1の画像 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Motor Replacement: 手順 8、 1の画像 1
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Roller Brush Motor Replacement, Roller Brush Motor: 手順 9、 1の画像 1
    • The wires are attached to the motor, so take out the motor slowly to ensure that they do not break.
    • Remove the roller brush motor by carefully lifting it out of the vacuum.
  10. Shark NV352 Roller Brush Motor Replacement: 手順 10、 1の画像 1
    • Desolder the wires running to the motor from the motherboard. For details on how to desolder, visit this soldering guide.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Wesley T Benica
メンバー登録日: 09/22/17
378 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G5, Forte Fall 2017 Cal Poly, Team S18-G5, Forte Fall 2017人のメンバー
CPSU-FORTE-F17S18G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 16
過去 30 日: 48
今までの合計 3,077
