はじめに
This guide demonstrates how to replace the button panel on your Shark ION Robot 750 robot vacuum. The button panel is important for powering the robot as well as the docking function. You may need to replace your button panel if you find that the robot does not turn on, the buttons have become dislodged, or break.
Before you begin this repair, make sure that your device is turned off.
必要な工具と部品
Use a spudger to remove the top case of the vacuum.
Flip over the top case.
Use tweezers or your hands to remove the center button panel from the socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
