はじめに
If you need to replace the motor of your Shark Flex DuoClean, follow this guide. To remove the motor, soldering skills are required. See this guide for soldering instructions.
必要な工具と部品
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Orient the vacuum so you are looking down at the open garage of the vacuum.
Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
6 の人々がこのガイドを完成させました。
7 件のコメント
Can this motor we test it before taking it out
craigfranz - 返信
Can this motor be tested before taking it out?
craigfranz - 返信
How do I know if the motor is burned out
