メインコンテンツにスキップ
Sega Dreamcast GD-ROM Replacement
必要な工具と部品
  1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: 手順 1、 2の画像 1 Sega Dreamcast GD-ROM Replacement, Expansion Bay: 手順 1、 2の画像 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast GD-ROM Replacement: 手順 2、 3の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 2、 3の画像 2 Sega Dreamcast GD-ROM Replacement: 手順 2、 3の画像 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast GD-ROM Replacement, Top Cover: 手順 3、 1の画像 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast GD-ROM Replacement: 手順 4、 1の画像 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast GD-ROM Replacement, GD-ROM: 手順 5、 2の画像 1 Sega Dreamcast GD-ROM Replacement, GD-ROM: 手順 5、 2の画像 2
    • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  6. Sega Dreamcast GD-ROM Replacement: 手順 6、 2の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 6、 2の画像 2
    • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  7. Sega Dreamcast GD-ROM Replacement: 手順 7、 2の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 7、 2の画像 2
    • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
    • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  8. Sega Dreamcast GD-ROM Replacement: 手順 8、 2の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 8、 2の画像 2
    • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
    • Remove the GD-ROM by gently lifting it from its base.
  9. Sega Dreamcast GD-ROM Replacement, GD-ROM: 手順 9、 2の画像 1 Sega Dreamcast GD-ROM Replacement, GD-ROM: 手順 9、 2の画像 2
    • Replace the bad GD-ROM drive with a functional one.
  10. Sega Dreamcast GD-ROM Replacement: 手順 10、 2の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 10、 2の画像 2
    • Secure the new GD-ROM drive to the console with the Philips #2 screws.
  11. Sega Dreamcast GD-ROM Replacement: 手順 11、 3の画像 1 Sega Dreamcast GD-ROM Replacement: 手順 11、 3の画像 2 Sega Dreamcast GD-ROM Replacement: 手順 11、 3の画像 3
    • Connect the three GD-ROM cables to the logic board.
    • Connect the GD-ROM data ribbon to the logic board.
ゴール
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Thorr686
メンバー登録日: 11/06/09
472 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G1
5 メンバー
21のガイドは作成済み
コメント 1 件
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 145
今までの合計 33,847
