このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
2 の人々がこのガイドを完成させました。
2 件のコメント
Very helpful guide. Do you have a manufacturer and part number for the touch screen?
