メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Samsung WB1100F Motherboard Replacement
必要な工具と部品
  1. Samsung WB1100F Motherboard Replacement, LCD Screen Cover: 手順 1、 2の画像 1 Samsung WB1100F Motherboard Replacement, LCD Screen Cover: 手順 1、 2の画像 2
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
  2. Samsung WB1100F Motherboard Replacement: 手順 2、 2の画像 1 Samsung WB1100F Motherboard Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
  3. Samsung WB1100F Motherboard Replacement, LCD Screen: 手順 3、 2の画像 1 Samsung WB1100F Motherboard Replacement, LCD Screen: 手順 3、 2の画像 2
    • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
  4. Samsung WB1100F Motherboard Replacement: 手順 4、 3の画像 1 Samsung WB1100F Motherboard Replacement: 手順 4、 3の画像 2 Samsung WB1100F Motherboard Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Flip the LCD screen over to reveal the display cable.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  5. Samsung WB1100F Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove two 1.2 Phillips #00 screws connected to the motherboard.
  6. Samsung WB1100F Motherboard Replacement: 手順 6、 1の画像 1
    • Desolder five wires connected to the camera motherboard.
  7. Samsung WB1100F Motherboard Replacement: 手順 7、 2の画像 1 Samsung WB1100F Motherboard Replacement: 手順 7、 2の画像 2
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
    • Detach the five ribbon cables from the camera motherboard.
    • The white line on the ribbon cables mark the edge of the connection area. To reinstall, insert the cables into the connector up to this line, and then close the retaining flap. If a cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  8. Samsung WB1100F Motherboard Replacement: 手順 8、 1の画像 1
    • Gently remove the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jesse Lindsey
メンバー登録日: 05/13/16
581 ポイント
5のガイドは作成済み
チーム
Metro State, Team 1-1, Carpenter SU 2016 Metro State, Team 1-1, Carpenter SU 2016人のメンバー
MSU-CARPENTER-SU16S1G1
3 メンバー
5のガイドは作成済み
コメント 1 件
Great Jesse, I can say the same applies for the WB100, I get one and I already disassembly it to fix humidity condensation in the top buttons, unfortunately the flash stops working..
Congratulation for your post. Enrique
egyr - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 918
