メインコンテンツにスキップ
Samsung SmartThings Hub Ethernet Port Replacement
必要な工具と部品
  1. Samsung SmartThings Hub Ethernet Port  Replacement, Ethernet Port: 手順 1、 1の画像 1
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
  2. Samsung SmartThings Hub Ethernet Port  Replacement: 手順 2、 3の画像 1 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 2、 3の画像 2 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 2、 3の画像 3
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
  3. Samsung SmartThings Hub Ethernet Port  Replacement: 手順 3、 3の画像 1 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 3、 3の画像 2 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 3、 3の画像 3
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
  4. Samsung SmartThings Hub Ethernet Port  Replacement: 手順 4、 2の画像 1 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 4、 2の画像 2
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
  5. Samsung SmartThings Hub Ethernet Port  Replacement: 手順 5、 2の画像 1 Samsung SmartThings Hub Ethernet Port  Replacement: 手順 5、 2の画像 2
    • Place the motherboard on a clean, flat surface.
    • Preheat your soldering iron. The Ethernet port has fourteen points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the Ethernet port away from the board.
    • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
    • For more information on soldering refer to How to Solder and Desolder Connections
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Erin
メンバー登録日: 09/28/17
494 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team S2-G4, Crane Fall 2017 Eastern Washington University, Team S2-G4, Crane Fall 2017人のメンバー
EWU-CRANE-F17S2G4
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 713
