メインコンテンツにスキップ
Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement
必要な工具と部品
  1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: 手順 2、 1の画像 1
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: 手順 3、 1の画像 1
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: 手順 4、 3の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: 手順 4、 3の画像 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: 手順 4、 3の画像 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 5、 2の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 5、 2の画像 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: 手順 6、 1の画像 1
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 7、 3の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 7、 3の画像 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 7、 3の画像 3
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 8、 2の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 8、 2の画像 2
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 9、 1の画像 1
    • Remove the evaporator cover.
  10. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: 手順 10、 3の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: 手順 10、 3の画像 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: 手順 10、 3の画像 3
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 11、 1の画像 1
    • Remove the screws securing the back panel to the evaporator cover.
  12. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 12、 3の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 12、 3の画像 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 12、 3の画像 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 13、 3の画像 1 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 13、 3の画像 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 13、 3の画像 3
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 14、 1の画像 1
    • Remove the screws securing the fan to the evaporator cover.
  15. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: 手順 15、 1の画像 1
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
終わりに
Repair didn’t go as planned? Ask our Answers Community for help.
作成者
1人の作成者と共同作成されました。
nicO
メンバー登録日: 04/14/15
15,885 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
546のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 43
過去 30 日: 213
今までの合計 1,759
