メインコンテンツにスキップ
Samsung Refrigerator Door Sensors Replacement
必要な工具と部品
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: 手順 2、 1の画像 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: 手順 3、 1の画像 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: 手順 4、 2の画像 1 Samsung Refrigerator Door Sensors Replacement: 手順 4、 2の画像 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: 手順 5、 1の画像 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: 手順 6、 2の画像 1 Samsung Refrigerator Door Sensors Replacement, Sensor information: 手順 6、 2の画像 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: 手順 7、 2の画像 1 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: 手順 7、 2の画像 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: 手順 8、 2の画像 1 Samsung Refrigerator Door Sensors Replacement: 手順 8、 2の画像 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: 手順 9、 1の画像 1
    • Remove the door sensor.
終わりに
Repair didn’t go as planned? Ask our Answers Community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
561のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 88
過去 30 日: 389
今までの合計 2,649
