メインコンテンツにスキップ
Samsung Refrigerator Control Panel Replacement
必要な工具と部品
  1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 手順 2、 2の画像 1 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: 手順 2、 2の画像 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 手順 3、 3の画像 1 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 手順 3、 3の画像 2 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: 手順 3、 3の画像 3
    • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
    • Insert a spudger into the seam along the right edge of the control panel.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Press the spudger in firmly and pry to loosen the panel.
    • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
  4. Samsung Refrigerator Control Panel Replacement: 手順 4、 1の画像 1
    • Flip the control panel over to reveal the cable connector.
  5. Samsung Refrigerator Control Panel Replacement: 手順 5、 2の画像 1 Samsung Refrigerator Control Panel Replacement: 手順 5、 2の画像 2
    • Use your fingers to slide the cable connector out of its socket.
  6. Samsung Refrigerator Control Panel Replacement, Remove the control panel: 手順 6、 1の画像 1
    • Remove the control panel.
終わりに
Repair didn’t go as planned? Ask our Answers Community for help.
作成者
1人の作成者と共同作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
チーム
Team Vulcan Team Vulcan人のメンバー
Staff
6 メンバー
212のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 121
今までの合計 3,548
